Bolt Pattern ?'s What to take from the yard?
Heep
Nebraska
I have the Waggy 44 Front axle that is 6X5.5 and I need to get it to 5X5.5
I know you can do this by changing the spindles or whatever from a F-150.
So...
When I go to the junk yard to get the parts for this swap
What exactly should I get off the ford at the junkyard to this swap. Also what does it involve?
Thanks
BTT
Spindle: '73-'76 Chevy K5/K10 or '73-'76 Waggy (small inner bearing)
Bearing: '73-'76 Chevy K5/K10
Hub: '76-'84 F-150/Bronco
Rotor: '76-'84 F-150/Bronco
Wheel studs: '76-'84 F-150/Bronco (1/2")
Caliper : '73-'?? Chevy K5/K10 (or Waggy)
Pads: '73-'?? Chevy K5/K10 (or Waggy)
Thank You :angel:
