- San Bruno, CA.
Are those the ZJ or XJ springs?
Either way that may be part of the problem, those springs are really soft for heavier rigs.
For relevance, I was running the RE ZJ 5.5" springs with 275/78 Bilstein 7100s. I had quite a bit of body roll in the front end when when dropping off obstacles so I switched to a Skyjacker 8" XJ coil which has a much stiffer spring rate. I had been really happy with that setup over the last several years(40,000+ miles) untill my rig lost 500+ pounds. Now I'm wanting to go back to a softer coil.
