- San Diego
yes it is hydraulic, you have to mount yours solid. To work full sticks you have to have a large clear area some times i have to load tube from both sides to get the bends i want so you need 20 feet out each end and 20feet on one side and 10 feet on the other side and the cages i do can have 12 bends in one stick so you don't piece the stuff together i do very few butt welds
Good, because that's illegal, Larry.I suck at exposing lol
SpecFab does all that pretty tube work then I come in and cover it up with sheetmetal and paint.
That is what I was trying to tell you buying it is the easy part
Most people waste $500 in tube and give up and never use it again
How did you do in geometry and trig and calculus in school
Its all math I have been bending for over ten years and got my basics working for minieke its all in the start of bend and that is different on every die and spring back is different in different dies and different tubing
There is no easy way to explain how to bend and what you are trying to do is the simple part get in to compound bends and put 6 bends in a tube at all different angles its a pain in the ass
Sounds like your overthinkinking it. Once you make a bend you should be able to figure out where you need to start your bends and how much material a bend takes.
From there you should be able to do most basic projects, then its just practice.
This has been my main thought in this thread:eeks1:
read this.
http://www.pirate4x4.com/tech/bendin_tube/index.html
and with a Jd2, there should be NO slippage of the tube in the die. that is what the u-strap is for.
