shortxjdoug
- Chattanooga tn
Install spare ps pump and cooler
Leaf spring clamps
With my schedule this might take a week
Done.... Even have 2 rear shocks now.
Lets get this party started
Leaf spring clamps
I see you need a spare, would a worn out 31 MT on a factory size, bolt pattern wheel work? I see you are running 235's?Updating again.
Couple more things knocked off the list..
Install 235s done
Change CPS replaced this and the stator.. hope the code stays off for inspection
Register, plate, and inspect it need cel off to pass inspection
Get a spare tire need
Get battery hold down need
Align done
Fix AC grabbing one this weekend at NACfest. maybe get it in on monday
Pretty much just little stuff at this point. Plus packing and buying food/beer
Fix winch
Install winch
Come up with a magical way to fit a steering brace in my junk
I used angle and a pipe from lowes. LOL!
Pics? You have a stubby with winch so I'm just trying to figure how it's still possible.
Was a welder needed?
I need to:
Replace cb coax
Mount external speaker
Paint interior of cage
Maybe install e brakes shoes and cables
Like your Jeep!Yes a welder was needed..... how you think I made it with angle and pipe!!!???
http://s16.photobucket.com/user/xjghost/library/Jeep Fab?sort=3&page=2
All I have left now is:
Locker (may possibly skip this one depending on when everything else gets done)
Balls! Looks nice though.
Like your Jeep!
That locker will make your trip much more enjoyable. We can always install it at the campground :roll:
Need to quite adding things.....To do:
Register for crawl - Done
Swap out rear leaves - Done
Install shackle relocation kit - Done
Weld cage to shackle relocation kit - Ready to weld
Raise the shock mounts on rear axle - Ready to weld
Trim Shackles - Done
Double check brakes/adjust drums
Idler pulley - bought - Done
Reinforce bent LCA - Ready to weld
Reinforce front skid plate
Reinforce rear leaf hangers
Replace windshield, if time allows
