before the crawl my junk needs.....
Updating again.
Couple more things knocked off the list..
Install 235s done
Change CPS replaced this and the stator.. hope the code stays off for inspection
Register, plate, and inspect it need cel off to pass inspection
Get a spare tire need
Get battery hold down need
Align done
Fix AC grabbing one this weekend at NACfest. maybe get it in on monday
Pretty much just little stuff at this point. Plus packing and buying food/beer
Rough day..
Anyone know who would have ARB diff parts in stock?
Front locker has all its teeth broken off and the shop rebuilding it can get all the parts from ARB except for the flange Cap Part #: ARB-028502. It is out of stock they estimate 6-8 wks and somehow aren't aware of anyone that might have stock.
We have had 3 or 4 pretty costly things come up all at once in the last few days, things are going to be really tight.
ARB recently opened up a DC in Jacksonville where they're stocking a lot more parts than they have up in Washington.
Current XJ I'm building needs:
HP D44
Ford 9
37" Maxxis meats
Raceline beadlocks
Three link front
Liquid Iron Industries leaf spring sliders rear
JCR bumpers and armor all around
Roll cage
Hyline hood vent
HMF Fabrication 50" XJ light mount
50" ACX Offroad light bar
I don't think I'm going to be ready in time. :(
Have a few things left to do...
Fix AC
Put freshly painted front clip on
Install proper bumpstops
Install CB antenna
Replace power steering pressure hose
Replace valve cover gasket
Install shackle boxes
Install hood pins
Buy new battery
Mount spare on steel wheel
Change oil
Check fluids, joints, grease fittings
Pack tools and spare parts
Would like to get done...
Relocate CB antenna
Get new tail pipe installed
I cannot wait for this trip! Gonna be a great time!
Updating again.
Install 235s done
Align done
I see you need a spare, would a worn out 31 MT on a factory size, bolt pattern wheel work? I see you are running 235's?
I need to:
Replace cb coax
Mount external speaker
Paint interior of cage
Maybe install e brakes shoes and cables
Fix winch
Install winch
Come up with a magical way to fit a steering brace in my junk
Fix winch
Install winch
I used angle and a pipe from lowes. LOL!
All I have left now is:
Upper control arms
Fix exhaust where my front driveshaft won't annihilate it
Spring retainers (run tap through the holes)
Get track bar situation straightened out
Locker (may possibly skip this one depending on when everything else gets done)
To do:
Register for crawl - Done
Swap out rear leaves - Done
Install shackle relocation kit - Done
Weld cage to shackle relocation kit - Ready to weld
Raise the shock mounts on rear axle - Ready to weld
Trim Shackles - Done
Double check brakes/adjust drums
Idler pulley - bought - Done
Reinforce bent LCA - Ready to weld
Reinforce front skid plate
Reinforce rear leaf hangers
Replace windshield, if time allows
Need to quite adding things.....
