Beezil and other long arm mounters :)
Looks nice, Jeff. Did you end up using sleeves in the front as well, or did you leave the "pushed out" subframe as is?
-Jon
I added one sleeve in the front section just above one of the existing cross member bolts, but did not put a sleeve in the very front section as I couldn't get a drill into the inner area (needed a right angle unit) and I was running out of time. Jeff
