Jeff 98XJ WI
- Butternut, WI
Hey Beezil and others that have made their own long arm mounts, I am wanting to see pics of the inside of the frame rails where you built reinforcements for the frame/long arm mounts. I poured over Beezils pics as that is pretty much how I have proceeded so far, but cannot tell how he did the inside of the frame rails in the front portion where the inside of the uniframe has a lip extending in. I used 4x6x1/4 box tubing ripped into two U-channels 3x4 to cover the rear portion of the frame and the front outer portion, but am undecided about how to finish the inner front portion. I think some folks simply extend a flat plate along the bottom of the frame rail and don't bring it back up along the inside of the frame rail. Rusty's pics show that is what he did for his long arm kit, but also added a piece of flat stock on the inside of the frame above the seam for a backer for some through the frame bolts. I don't know if he is using any sleeves in the frame. Doesn't look like it. I might do this also, but am just wondering what others have done or would do. BTW, I did use some sleeves and through the frame bolts on the rear portion of my frame reinforcement. Thanks, Jeff
