RubiconKid95
- Auburn, WA
Cupholders
...sorry just had to
do you know of the break down on the bearings so we can all make sure we have the correct ones? thanksSince we are talking about it.
There are at least 2 different sizes of unit bearings and depending on your wheels they may or may not fit either.
There are at least 2 different sizes of unit bearings and depending on your wheels they may or may not fit either. You should be aware of this if you carry spare D30 shafts with the unit bearings attached.
Unit bearings are NOT difficult to swap on the trail if they have been properly prepared and installed in a clean environment within the last couple of years.
I would carry spare D30 shafts for 33's and up.
Michael
FixedGood stuff, as usual Michael. Tools that you carry are of course geared around your particular rig, but some basics that everyone ought to carry include the following:
BFHammer
Large punch/alignment tool
1/2", 3/8", 1/4" racket
Extensions for above, 4" and 8-10"
Socket sets for the above, regular and deep well, 1/4" to 1"
Socket sets for same, regular and deep well, metric, 10mm to 24mm
Screwdrivers, flat and phillips, large and small tip, including a stubby of each
Combination wrenches, 1/4" to 7/8", Metric 8mm to 18mm
Allen wrenches, full set both standard and metric
Torx bits, full set
Adjustable wrench, up to 1 1/2"
Pry bar, at least 18"
Vice-grips, large and small
Channel locks and slip-joint pliers
That is just a basic set, include any odd-ball sockets particular to your rig (ball-joints, hub-locks, axle bearing retainers, whatever) Include a sturdy box or heavy-duty bag for the above. Organize it so that everything can be found in ten seconds or less. Socket strips that firmly ball-lock them in order are very handy. Loose little sockets are a real time-killer while conducting trail repairs.
Add to the above as you see fit.
good shit Micheal !!!!
Here are a cpl suggestions to add....
Lug wrench / 4 way
at least 4 extra lug nuts
something to write with and on (sharpi and scratch paper)
Ratchet strap
lug studs to go with the nuts...they break to
"Tow strap with NO hooks" Why no hooks?
I'll probably copy the latest version into the NWF forum. I also think the list would fit nicely as a sticky in an "upcoming events" forum though.Below is the updated list.
Do we want to sticky this somewhere? We talked about this originally. It might be useful for the Noobfest coming up?
Michael
