- In the islands
I was trying to remove the rear shocks and broke one of the bolts. I panicked after that mishap and abondon the job until I have a chance to regroup or re-coup from my anger. Some where I heard that some of you use a bar pin eliminator. What do you use and how do you fasten it? I already got myself a drill bit and tap 10mm X 1.50 so that I could use a larger bolt and hopefully prevent this from happening again. Now if I could rid myself of that 'split ends bar pin.
Thanks.
Thanks.
