Looks like the axle is mounted too far to the rear.Do you plan to bumpstop the hell outa it?
i was waiting for somebody to say that!!! :laugh3:
:conceited
the shims are real small, they aren't like blocks or anything, i cant see them causing any axle wrap issues, please tell us whitney, sup with the shims?
his axle has cast in leaf spring mounts, so he cant just rotate the axle and weld the mounts in place where they need to be, if thats what you were implying.
curious on your reasoning, please respond.
Sorry it took me so long to respond. Axle wrap isn't the issue, it has more to do with the constant twisting motion the front springs are subject too. It's the same concept as why blocks aren't used in the front for lift: There's to much chance of it slipping out or getting shot out for that matter. You'll hear of a lift block in the rear slipping out once in a great while, but never a shim. But the rear doesn't steer so there's no side load on it like the front. I'd cut and rotate the inner C's before I'd ever shim the front. Cutting and turning the inner C's isn't half as difficult as some people make it out to be, you just need a cut off wheel, an angle finder, and a 220V welder. With what you guys have done already, you shouldn't have a problem.
the inner C's is not the problem. my pinion angle is the problem. the dana 44 i am using has cast spring perch on the passenger side, but the the driver side has a welded on perch. i still dont know exactly what i am going to do, i need to get some tires on the front axle and see where it sits, still waiting for parts from 4 wheel parts(sometimes i hate dealing with them, but i get a discount because we do their towing) the store manager said my parts would be there tomorrow so well see what happens this weekend....
Ah! I'm sorry, I missed the cast spring perch! Check where the plug welds are, your tube should be pressed all the way to the diff. You can just cut the spring perch off and make one and burn it in. The cast spring perch wouldn't provide enough material for the tube to be just pressed into that, so you should see plugs welds on the front and rear of the diff below and to the inside of the perch .
