SeanP
- Rocklin, CA
C-ROK said:Actually, No.
There are no cheap third members for a 35 spline 9".
35 Spline requires the aftermarket 3.250" main bearing cases. Stock Ford stuff is all 3.0625" (with the noted exception of some very, very rare muscle car cases from the late 60s).
A 33 spline is the biggest shaft you can run in a stock case. And only spools are available for the 33 spline.
I used the Strange nodular iron case. Once completed with the pinion support, spool, bearings, billet yoke and gears it was almost $1300 delivered from Randy's R&P. Had I have gone with a locker rather than the spool, you could have added another $200-$500 to that price.
The cheapest way to go 35 spline (or equivalent) is to do a D60 or 14B.
I'm an absolute lover of the Ford 9" axle but once you get beyond the 31 spline factory options, being cheap is no longer one of it's benefits.
My Strange Nodular case for the 3.25" bearings was NIB on Ebay for $219, pinion support was $60, R&P $199, bearings and setup kit, $139, and detroit was $485 at the time. Just under $1200, but I did the set up myself. And of course when I say "I", I mean "Crash".
This is all for low pinion. TruHi9 is about twice what I have into my lowpinion from what I read. Not sure if the bang is worth the buck in a longer wheelbase rig, but that's a whole nother debate.
SeanP
