Roostertail
- New York State
I like the idea of staying with 5 on 5.5" rims, mostly because I already have them. I could convert a 60 or 14 bolt to 5 on 5.5" but then I'm spending more money than the 9"
I believe there is a ford van that had a D60 and 5 on 5.5...Roostertail said:I like the idea of staying with 5 on 5.5" rims, mostly because I already have them. I could convert a 60 or 14 bolt to 5 on 5.5" but then I'm spending more money than the 9"
I'm not sure you even can convert a 14B to 5 on 5.5".Roostertail said:I like the idea of staying with 5 on 5.5" rims, mostly because I already have them. I could convert a 60 or 14 bolt to 5 on 5.5" but then I'm spending more money than the 9"
Ghost said:I believe there is a ford van that had a D60 and 5 on 5.5...
C-ROK said:I'm not sure you even can convert a 14B to 5 on 5.5".
Converting a D60 however is not very expensive at all.
To convert a FF D60 to SF w/ 5 on 5.5" is pretty easy. You use 9" big bearing housing ends. These are available all over for about $70-$90/pair. You could actually even cut the ones off your current housing and re-use them. For the cost though, it probably doesn't make sense to bother with it.
Simply cut the ends off the 60 housing and weld on your new 9" housing ends. When welding the ends on, you use a 1.5" solid bar alignment tool through the housing ends and carrier bearings to keep it all straight.
For shafts, you use the exact same 35 spline 9" shafts you would be using on your converted 35 spline 9.
All your exisitng 9" brake components can then be swapped over too.
Not necessarily better than a 35 spline 9. Probably a little cheaper but also more work than simply buying a new third member and shafts and bolting them all in.
Of course you could also probably sell your current 31 spline 9, sans brake stuff, and help pay for a good chunk of building the 60.
There is no such thing as a 1.50" dia, 35 spline 14B shaft.Roostertail said:Why couldn't you do the same to a 14 bolt?
C-ROK said:There is no such thing as a 1.50" dia, 35 spline 14B shaft.
The D60 35 spline shaft and Ford 9" 35 spline shaft are dimensionally identical.
In short, 35 spline 9" shafts fit into 35 spline D60 carriers. The 14B and D70 both use different shaft diameters and spline counts.
You could weld the housing ends on the 14B but you can't get semi-floating shafts that fit into the carrier that I know of.
xjfan1974 said:You're right wheeling in Ks & West Coast are different. Here in KS are wheelin is too easy for the hardcore wheelin the west coast. Whatever... Beside KS isn't only place we wheel. But hey if you ever get a chance to come to Randolph, KS ORV park I can show you just how easy it is to wheel in KS.
Have you seen my Dana 40?:confused1Goatman said:I'm looking for something stronger with less than a 25% chance of breaking, maybe even less than 10% chance.
No, but I'll post you of my 44 getting blinged this weekend if you want.....Okie Terry said:Have you seen my Dana 40?:confused1
bheit4x4 said:ive been wheeling my 33 spline 9 for a little while now and i have no issues with breakage inside the axle and im running 39.5 pitbulls. on a side note i would say truss/support the hell out of a 9, i got about 3 trips since i 4 linked mine and the btf truss started to ripp the top of the housing off.
Capt. Nemo said:Didn't know 9's came in the 33 spline flavor
bheit4x4 said:yep smartypants get a 33 slpine spool and shafts and your good. IMHO if your going to build one you might as well start here only a few hundred more than building a 31 spline
