No caliper; no knuckle. It's a rear axle; and yes, you'll have to manually count the splines. Even if you could find a date that the switch was supposed to happen on, Jeep is/was notorious for slapping on whatever part happens to be around.rocklandxjer said:just pull the axle shaft, still involved, but alot less than opening up the case and draining hte fluids.
remove caliper, unbolt shaft from knuckle, pull shaft carefully
count splines, then do the reverse lol
you drained the diff, removed the carrier pin, pulled the c-clips, and pulled the shafts ,and u did this a couple times for shits and giggles? obviously it wasnt to count splines cause you have a 94' and its 27 no matter what, :twak:rocklandxjer said:no, i know all of that lol ive pulled my rear axles a couple times before, i dont know why i just heard axle and i thought of my d30, its just been on my mind i guess
Its ok, you should.rocklandxjer said:damn i feel so stupid
