Axle Bracket Placement
JT86XJ
Columbiana Ohio
I'm starting to lay out the mounts for my HP D44 for my Xj. Wanting to do a 3 link, upper arm on pass. with a truss to the diff., lower mounts with coil buckets. My question is can I run the one upper arm on the pass. side, wont be driven alot on the street, but will see some street time. Thanks
yes. its fine on the street. Just build everything strong enough.
Good, then i can start tacking them in once I figure out the measurements. I got the brackets from ballistic, and Im having the local weld shop, do the welding just to be safe.
Thanks
