scully
- ma/nh border
ok- came across this info-
if i understand correctly, both solenoids off=4th
reverse needs #1 to fire in order to produce reverse.
and neutral needs #1 to fire to produce neutral.
if ONLY #2 were firing, i would at least have 3rd.which i do.
and #3 solenoid ONLY controls torque conv.
sooooo, it stands to reason my #1 solenoid is not functioning?
Position Solenoid
"D" (Drive) #1 solenoid #2 solenoid
1st Gear .................. ON .................... OFF
2nd Gear .................. ON ..................... ON
3rd Gear .................. OFF .................... ON
4th Gear .................. OFF ................... OFF
"3"
"1-2"
"R" (Reverse) .............. ON .................... OFF
"N" Or "P" ................. ON .................... OFF
(1) - Valve body contains 3 valve body solenoids. See
Fig. 2. No. 1 and 2 valve body solenoids are used
for controlling transmission shifts. No. 3 valve
body solenoid is used for torque converter
lock-up only.
Position Solenoid
"3"
"1-2"
lock-up only.
