- Thornton, CO
Whats the best price anyone has gotten on one of these?
cal said:4wheelersupply.com
$540 delivered. Ask for the "socalxj" price.
91 Jeep Project said:
This still holding up?bj-666 said:party1: IT WORKS. well after many problems with my old ected they decided it was best for both of us to send me a brand new one. not only that but they didnt' just send the unit they send the full install package lube wires switch all the good's my hat's off to auburn for there customer service they were very pleasant to talk and work with.
performance: just finished putting it in and took it for a ride around the block it locked like it should when engaged it would scrub the tires with no slipage of the locker. i have yet to test it on the trail but it already seems like a whole different animal than with the old unit. after some more extensive testing i will let ya all know as to how i feel about the ected
conclusion: as of right now i feel that all the problems with my unit were because of defects. more info to come with more testing.
there was a few time were it didnt seem to lock up fully, but it was workin a milloin time better than at nac festnhrocker said:I forgot to update on mine. I had some issues at first with mine not locking, but on a recent run it was working correctly. Mine seemed to just need some break in time. At this point I'm very happy with it's performance not just as a locker, but as a limited slip as well.
sounds like my detroit in the rear.Jeeper said:As of right now my ected will sometimes pop when its not engaged. I dont know what the problem is but I'm going to try changing the differential fluid and see what happens. It'll usually pop when I am doing a sharp right turn on pavment, and its especially profound when I'm more generous with the gas pedal. I'm thinking that the LSD is locking up and then sliping in a fashion that creates a pop.
Jeeper
guther66 said:I purchsed a D30 ECTED and also had proplems with it. The first two times I engaged it, it popped. After that, nothing. I played around with it inside the diff. and noticed that the magnet wouldn't pull the "washer/plate" over far enough for the locker to fully engage. I've sent it back and they worked on it and sent it back. The engineer didn't say anything about it when I talked to him on the phone. I got it back last night and played around with it. I hooked it up to a battery and still the same thing. It pulls the shims but the "washer/plate" doesn't get pulled all the way over. The "washer/plate" I talk about sits between the coil and the locker housing. It basically as the same OD as the coil. For those that had problems with theirs, I was wondering if you noticed the same type of thing.
I do have to say though, great customer service when you can get a hold of someone.
