Cal, I meant the joint mostly. Read my whole thread and I stated the shaft could be broken, but it's unlikely. Seems the R&P might actually go first.
Agreed, but a 27 spline shaft and the d30 R&P are both weaker than a CTM joint already - so going to a yet stronger (in some opinions) joint is has little benefit. I'd rather run 30 spline inners and outers with a CTM than 27 spline inners and outers with a CV joint.
I think the main benefit of the RCV's at that point is how it improves your turning while locked ability. And RCV's are offered in 30 spline also.
Anyone ever use Complete Offroads kit? I think its Yukon, because with their gears they use a noname and ship you yukon for a cheaper price. Any thoughts?
http://completeoffroad.com/i-378648...-axle-kit-w-760-u-joints-27-spline-24110.html
They offer a lifetime warranty against breakage. For that price it seems like a great deal to me.
warranty's don't get you off of the trail.. and yukon products are sketchy.![]()
Called them up, they are Yukon shafts. Good deal with the warranty.
Yukon warranty only covers up to a 33" tire? You could just run stock axles with those tires, what a waste lol.
With alloy shafts in a D30-what is the weak link? The R&P?
If so, wouldn't it be better to replace a shaft than a R&P.
Thoughts or experiences?
would you rather replace a ring gear every couple of years, or a shaft every couple of runs?
you have to really try to break the ring gear. 4:1, in reverse, on 35's, uphill, bound up.. they don't break all willy nilly unless you have other problems going on (bent housing, etc).
you can do a lot to protect the ring gear just running a strong diff cover, or a truss properly welded to the third. before the ring gear goes, the third member deforms enough to let it deflect.
