chedisme
- middletown, NY
It's a website
You're a website!
It's a website
I feel your pain man. I was in the purple late model XJ you guys PASSED in the Mesquite, NV area on the 15 headed to Moab. I was loaded down like crazy had at least 4-500lbs of crap stuffed in, plus all the offroad stuff. I sturggled to keep 70 on anything but flat road or down hill. My heep heats up a little more then i would like on the up hills also so im pretty much in the same situation you are. Gunna check the cat. And start budgeting for a stroker.
Looks like the consensus is definitely that my engine is being normal. I guess thats good, although a little disappointing because i dont like going slow :rof: good to know im not the only one crawling over grades at 4,000+ rpms
i guess now that i think about it, 5,000 lbs and a parachute of a tent strapped to the back is not a good recipe for speed on a vehicle with sub 200 hp, 33s, and inadequate gearing. :gee:
Interesting discussion so far.
For the OP, is this happening only when you are loaded up for camping, w/ the tent?
I had similar "symptoms" with my first XJ, in the hills of PA w/ a canoe on top of a roof rack. Plus 2 people w/ gear for 3 days on a river. Luckily, that trip wasn't the time it threw a rod (that was after a trip that got it hydro-locked) going up the highway in PA. But, that trip with the canoe really sucked on throttle response and MPG.
If it occurs mostly with your camping setup, I would suggest trying to make your setup a little more aerodynamic. Looking back at the original picture, I would buy a big tarp to put over the whole mess when you are on the highway. That should clean up the air flow enough to help.
That would be a cheap investment to try before getting new gears. Should help regardless of the gears.
My thinking is that if you were hauling a smooth box of the same weight, you would probably be doing better. But you're literally carrying a big messy parachute on your back end. When I had a spare tire on my roof rack, it was a 1-2 mpg drop. The canoe took it down a good 8-10 mpg.
and i like your tarp idea. might have to try out something like that. would also be cool if i could get the tarp to wrap around the tent rack, and function like a soft camper shell.
on another note, i wonder if putting a wind deflector in front of the tent would help at all? you know, to make the air go over the tent smoother?
that thing would haul ass with a 4.0 in it..![]()
