- Southern Maryland
Good old kastein measured his spare AW4 and got a radius of 6.5" from the center of the shaft to the CKS mounting surface. That works out to a circumference of 40.84", which divided by 360 gives .113" for every one degree of rotation. That's less than 1/8th inch of movement, and less than 1/2" for 4 degrees advance. It might be possible to cut the slot a little bit and get there.
