Adjustable Steering Stabilizer?
NHextremeXJ
Keene, NH
Does anyone manufacture an adjustable dampening steering stabilizer?
Personally I wouldn't use a shock as a steering damper. A shock is setup with different amounts of damping on compression and extension. A steering damper has the same amount of damping for both. Unless you ran two shocks and mounted them opposite each other. But I would think that would be overkill.
Sorry can't help you out more.
I agree 'overkill' but it IS a good idea. I never thought of that.
Do the manufacturers valve the steering stabilizers differently for each vehicle?
Good point I did not think of that. Well I tried JOE>
