Adding a couple inches
lostcreek21
Gresham oregon
Hey guys. I have an 87 cherokee with 3 inches of lift and I'm wanting to add a couple more inches. I'm planning on adding 1 3/4" front coil spacers and 1.5" rear shackles. I'm then gonna run 31x10.5 BFG MT's. There will also be 4* shims in the rear and new LCA's. I also don't want to spend the money on a SYE so I want to go as high as I can without one. Does anybody have any advice about this setup or any pictures of something that looks close to this? Thanks
A friend tried to do exactly what you're doing last Fall. He went from 3" to 5". Took it out for a test drive and the drive shaft fell out less than a quarter of a mile down the road.
I don't think you can go that high without making some provision to extend your drive shaft. Even if it isn't an SYE, you will need a longer drive shaft. Sorry.
Thanks for the info. I've heard of people having their local shop extend their driveshaft. Would anyone recommend that and what should it cost? I was also looking at the longer slip yoke that's 5/8" longer than stock. Would that be long enough?
Forget the $25 for an extending a Drive shaft. When I priced it, they would actually make a new drive shaft, using your old ends. They can shorten/balance a longer one for around $25. A MJ shaft would be perfect for that.
As far as the SY, I've beentold , the extended SY is off of a YJ (88-95) Wrangler please excuse if the years aren't perfect. Also I rember that if you find a S10, it may have an extended SY, or longer driveshaft to cut down. Your right, Ext Sy are aroung $60. Ask the local drive shaft shop if they have them or can get them. They may be cheaper, if you can't find one in a junkyard.
Would a drive shaft out of a cherokee with a manual transmission also work? I'm thinking about going down to a couple junkyards tomorrow and looking around to see if they have any.
Are you the one who keeps sending me emails about adding a couple of inches?
If so, who have you been talking to?
:next:
GaryE use to run a MT drive shaft and a Ext SY, with his AT tranny. I think he was only running 4.5", when he put on the 8.8 he had to go back to an AT one.
With the MT DS you don't need to shorten it.
I did this exact same thing, i added a trackbar to it...I have nothing, no shims, no tcasedrop, nothin...and I might add when I got my 44...I had my dshaft shortened 1"...its working great, when I go up to 6.5"s, ill get a stock dshaft...
i went to 5 like that and it worked fine on my 89'. it really depends on the jeep on how it reacts
lostcreek21 said:
Hey hjeepxj did you add LCA's when you added more lift?
I sure did, im pretty sure I wouldnt have HAD to....but i got them for 50$ u/l's (teraflex, and I dont have the uppers on yet) so i couldnt pass them up! id do them at that height, unless i was real poor, and if i was real poor, id just stay at 3"s
Here's my 93 at 5" with new LCA and 4 degree rear shim, clearence ground the output yoke and so far so good.
My first lift was a 3 inch pro comp with a 1.5 inch prothane coil spacer. I would not recomend this, without a new upper control arm it throws your caster all out of wack. And the outside of your tires will be gone real quick.
Did you have an alignment done after adding the 1.5" spacer. I ran 4.5" Rusty springs(which gave me closer to 5") and Rusty's CA's, I didn't have any excesive tire wear. The only thing I didn't like was the ride and that was from the CA angles not the arms themselves.
You can not adjust the caster, when you put on a linger lower control arm only, it pushes the bottom of the front end out so the spindel is not perpendicular to the ground anymore.
