5-Speed XJ
- Sunapee, NH
did you end up cutting and rotating the c's?
what are you doing about the bolt pattern for the wheels? Going 5x5.5 or keeping the 6 lug
6 lug getting shafts made for the 8.8
I would move the tb as far out as possible(closer to the coil), Ideally you want the tb longer than that..
I was going to say the same thing. I posted my first track bar that was about that length and everyone laughed at me.I would move the tb as far out as possible(closer to the coil), Ideally you want the tb longer than that..
Nice work.
The only thing I'm not too fond of are your upper control arm mounts at the axle.
Instead of just welding the DOM sleeve to the tubing, I'd take a piece of 3/8-1/2" plate and cut a half circle out of it to follow the sleeve right in the middle. Something similar to what Clayton does.
Gonna be hard to use square tubing of any strength since the joints are really narrow.
lock out hubs=no need tonice work, I know you answered my question about you not rotating the c's, but do you mind if I ask why you chose not to rotate them?
you can adjust the caster with the control arms just like a stock xjDoesn't rotating the knuckles have to do with caster angle and steering? Not the hubs right? If it will never see street time then it doesn't really matter. But propper caster setting helps with tracking and the wheels returning to center. At least that's what I have found.
