burntkat
NAXJA Member #1145
- Charleston, SC
Re: Acetone will increase MPG?!?!
I'd thought of that, but 50 miles seems like an awful small sample set.
crazy4mopar said:Ok here is todays report!!
I drove my 98 GMC Z 71 1500, 5.7L motor, 4x4 and stock tires.
I drove 103 miles at 70 MPH with no traffic. I averaged 19.43 MPG, thats almost 5 MPG more than no acetone!!!!![]()
On the return trip I drove a combination of stop & go city traffic, 40-50 MPH back road traffic and 75-80 MPH on the freeway. I averaged 18.05 MPG, thats about 4 1/2 MPG more than without acetone!!!!![]()
I say it's working:exclamati :exclamati
Alcohol does not increase milage it decreases it
I run alcohol in my modified we will burn 5 to 6 gal in a 15 lap race, On gas they only use around 2 to 3 gal in the same race. My alcohol carb uses 100 pri & 120 sec jets to supply the fuel. My gas carb only has 68 pri & 72 sec jets. The alcohol in pump is only there to take up space.
Slip Kid said:Does anyone out there with more chem knowlege than me know anything that can confirm that webpage's claim that alcohol INREACES surface tension?
My father reported a ~3 mpg increase over reg 87oct when he would use 89 oct 10% ethonol gas in his 93 (my motor now). He also tells me that 93 oct NO alcohol gives about the same mileage as reg 87 no alc. so either the ODB1 HO works best on 89 octane, or works better with alcohol over no alc.
if someone can prove the site's claim of alcohol increaces surface tension, I'll give acetone a try and see if the gain is better than the 89 oct 10% ethonol. if someone disproves the surface tension claim, I'll stick with the ethonol. 10% ethonol pump gas can be found cheaper than regular at all honest gas stations, at least here in the midwest - since 10% eth gas is acually cheaper in wholesale than reg no alc.
old_man said:Having spent some time in the commercial fuel additives business, maybe I can shed some light on this. The only difference between regular and premium fuels are the additives. They come out of the same spigot at the refinery. Octane is not a measure of the amount of energy in the fuel, but a measure of knock resistance.
Lucas said:Once and for all, 2oz of acetone in your tank is not going to wear out, burn through, or eat away anything.
