RCP Phx
- Phoenix,Az
We're still looking for a cam bolt washer, if anyone knows of one let me know!
Do you know what's used to clean up the cooling passages?
The Harlandsharp rockers are the same as the factory ones (1.6) and they install exactly as factory they are desinged to work with our hydraulic lifter cams. I started with HS rockers on my own 4.6 and did end up getting some new pushrods to get the proper lifter per-load before I installed Scorpion 1.7's. I started with a 2000 factory valve cover before going to a aluminum cover.
Thanks for your reply.
I like the looks of those Harland Sharp ones. They look familiar to those on the 500 CI Chevy blocks back then. I did remember using some stainless-steel ones also.
When adjusting them, did you turn them down 1/2 turn after 0 last? I did remember 3/4 turn for the regular guys and 1/4 turn for the go-fast crowd. There were also some solid lifter guys that had about 0.010 lash.
Just to be clear, the Harland Sharp roller rockers will fit under a factory valve cover without requiring the use of a spacer or any other mods?
It is a Moroso pan that Bill thought was a good idea....... I had nothing to do with it! He reads to many magazines, yesterday he was asking about the need to index the spark plugs!!!!
https://www.moroso.com/chrysler-jeep27862/
