Prevenge
- Quesnel , BC , Canada
Ok , long, stupid story made short as possible. procrastinated changing my worn battery cables which left me stranded...vice grip bandaid fix to get to the parts store. This caused my (+)-to-starter cable to wear through and fully ground out against the motor mount..enough that it killed the jeep in the middle of an intersection. Just died in a plume of smoke , which i discovered was probably cause by the braided manifold-to-firewall ground strap heating up and burning through the plastic split wrap for the wiring harness (on the other side of the engine from where the initial contact occurred.)
Now..somewhat luckily I died about 50 feet from the parts store so I was able to replace both the (+)-to-starter and the (-)-to-dipstick ground and drove it home. After a jumpstart I noticed first that it was idling terrible, stuttering and missing. Also my oil pressure gauge is pegged to the max with no sign of moving. I expect to have to replace a sensor or two. Just going refresh the contact for the ground and scout for shorts in the harness where it got melted but what I wanted to know is... What else does this type of electrical short have the potential to wreck? Should I be prepared to worry about the computer or should fuses/fuselinks protect most of that stuff?
