while putting on a lift and putting the shocks back on, we broke the bolt/nut to connect the shock to the shock mount (driver's side/back). The rest of the bolt was welded into the mount. Anyway, the question is, what should I do w/ this situation? Should I weld in factory replacement shocks? or, should I put on another mounting option (CJ, YJ, ETC.)?
Thanks in advance.
The lift is 2", mounts in front, shackles in back. 30's on it now, w/ hacked fenders, ill be fitting 33's, hopefully
Thanks in advance.
