Nice looking truck, Aaron... same mirrors as mine. Your rear springs look healthy too.
To answer your question Les, I used Rusty's 4.5 coils and LCA's w/ a 1.75" poly spacer and RE drop brackets, and KYB Monomax shocks for a 2" lifted TJ in the front of my MJ, with a custom trackbar and 1-ton inverted-T steering in the works. The back is stock springs on top of the axle. I used stock XJ rear shocks with the MJ spring plates because it was convenient at the time, but they don't offer enough travel. I have enough room to make lower shock mounts about 5-6" lower than where they sit now and not pass below the bottom of the axle tube, which will allow me to fit much longer shocks. The front end handles the washboard roads and sand dunes at the Badlands really well, but I bottom the rear short shocks too easily. It is only a short amount of work away from being fun at high speeds as well as low ones. I have 33's, 3.55 gears, Puegeot open disconnect D30 and spooled D44.
