IntrepidXJ
NAXJA Member #647
- Grand Junction, CO
egghead said:btw- what if I bolted it, and welded? Would that pass?
NO....the heat from the welding will change the properties of the hook making it unsafe.
egghead said:I cannot plug it Rev... When I plug it.. It runs like crap!
Egg
XJ_ranger said:use the bigest bolt that will fit in the hole (IIRC 3/4" is the standard size - that is pleanty strong...)
87manche said:I'll look on my vacuum tree in a few minutes when I get home and let you know where that hose goes
egghead said:Ok, so I have some pics..
This first pic is a little vacuum diaphram; I dont know where one hose goes..
I'm pretty sure this is why when I start the Jeep, It idles high.. then acts like it wants to die. but comes out of it and idles decent. Also when I rev it up multiple times.. it comes back down and wants to die.. Does anyone know where this vacuum line goes?
Egg
ILLXJ said:If you can't find a console, I have one from an 89. Gray in color. JIM.
So whens he gonna come and do my 8.8 install? What I was told looked lke an AMC 20 actually ended up being a 35, bummer. So now I'm back onto the 8.8 install. At least now I've got spare 35 shafts.LBEXJ said:Aaron picked up his 8.8 with 3.73 gears and a "posi-lock" this weekend and got started cleaning off the non-used hardware and brackets. He spent most of the day cutting brackets a grinding off the welds. He's got a newer axle with disc brakes, so he pulled the calipers and rotors off to take into his Auto Tech class. They have a lathe so he can clean the rust off the rotors. He'll push the pistons out of the calipers, clean them up so it moves freely, and replace the seals if necessary. He is also going to replace the pads. The emergency brake pads are fine. I advised him to replace the front pads on the truck too and make sure the front brakes are in good working order.
Great weather and a nice day relaxing over a project out in the garage. Aaron said "Man this is a lot of fun." I'm happy he is enjoying it.
Les
87manche said:So whens he gonna come and do my 8.8 install? What I was told looked lke an AMC 20 actually ended up being a 35, bummer. So now I'm back onto the 8.8 install. At least now I've got spare 35 shafts.
BOB said:I am real happy with my 8.8 with rear disc.
my best ungrade so far.
well, the Detroit and 4.88's are nice too!
...BOB
