- Bakersfield, CA
Speed_racer said:I'm moving for college, and WILL Not leave my XJ behind.
So here's the scenario, 8" or 10" lift front and rear, AA SYe, Woods Driveshaft, Clayton Long Arms, and all necessary Brake lines.
Looking at, for now, 35" tires.
What will I need to do with my steering to make this jeep "very streetable" , as it WILL get wheeled, it will also get a LOT of street miles.
ANy help?
To do it right, you'll need something that moves the steering over the knuckle. The problem is the severe angles of the drag link and track bar at that lift height. There isn't much room left in the movement of the joints, so they will wear out quickly with much off roading, then you're driving miles on the street with marginal or completely worn out parts. Those who say they are running stock stuff successfully at that lift just don't know the problems that they are about to encounter......and they either haven't run it long or rarely wheel. The TRE at the pitman arm is especially susceptable to premature failure. The stock parts are also very marginal with 35" tires on the trail, especially the stock drag link which can easily bend at the threads next to the adjusting coupling.
ORGS makes some parts to help you do it, but there is no actual kit to do the whole thing. There are any number of ways to do it, a search here should come up with plenty of discussion and pics. You can either reverse the taper on the knuckles, which takes brazing ability plus the correct tapered reamer, or just drill out the taper and use heim joints. If you can't make the links yourself, a number of off road shops sell ready made or custom links, and can also sell the hardware. The ORGS parts can be used to relocate the track bar over the axle, which is necessary to keep it aligned with the drag link for proper geometry, and ORGS parts can be used to move the sway bar links up to clear the raised steering links.
Here's a pic of my old D30 steering setup, just for some ideas.
