Well Ive been procratinating and still havent gotten a gradulated cylinder to measure yet but just to mess with what Im showing I need how would this work out.
Go to a veterinarian hospital and ask then for a 60 cc syringe ( Shot for a horses......large animals) there like $2
Comb Chamber Vol of 60cc
And removing some of the bumps in the pistons to 13cc
With all the old specs gets me a comp ratio of 9.6:1 using the current headgasket. My quench will be .021 below stock. Now I really need schooled on quench is that the difference between the new and old TDC? Or how far the piston sits below the deck?
Does that mean that you are .021" below the deck at TDC? or are you saying it is .021" below stock..... .042". This is vary important and need to be measured exact, before a accurate number can be figured
But whats a accepatble amount of quench for high altitude no more or less then .020 .015 .010?
Basically, Quench is the distance the piston is form the head( piston below deck at TDC + head gasket thickness)
Piston below deck (.030)
Head gasket ------- (.045)
______________=.075" Quench
less Quench, is better, but raises compression, and if your Quench is to tight, you could slam the piston into the head at top RPM. (there would have to be a lot of block decking to ever worry about that. on a stroker or stock 4.0L)
Also Ive desided to slow down but Im done doing work to the block so my problem need to be fixed with head and headgasket as listed before. Ill sand off some of the circles on the piston dishes to try and get 13cc out of them. As for the head once I measure the cc's I guess ill polish them to get every little cc I can out it.
Some other tech questions:
How far can timming be retarded or advanced before it can cause problems or consider improper use of a stroker?
Timing in non adj. time is set by the crank sensor and it is not adj.
Valve timming. Im all about getting torque out of it but is any damage cause by retarding I think it is, for torque? Do ignition and valve timming have any relationship to each other. Such as change one the other needs adapted? Reason Im asking is because once the timming chain cover goes on I dont want it removed for atleast 5years.
