Royal Nonesuch
- Pasadena, CA
Re: Rebuilt & tuned up RENIX running very rich
Got busy with work over the weekend, come back and look at all the replies! Thanks guys.
Thanks, I found the list of CA-compliant magnaflows for the XJ on their website. They also have a dealer/shop listed a few minutes from me, so I am going to swing by there this week and chat with them about it.
He has a lift/does repairs too and is a cool dude. I'll ask him about it, good idea. Maybe I can order the new cat and have him slap it in.
Very interesting. According to my records, I installed the 703s in mid-december last year/1800miles ago. The 02 sensor was installed in late May this year, so I imagine that is still good. During the time I ran the 703s I did do a few good 4x4 trips stressing it offroad. I have been watching ebay for SnapOn 2500s, they're pretty affordable but I'm not quite at the point of buying one yet. I might ask in the local chapter section if anyone wants to loan one out for a case of beer :yap: I'd love to be able to read that live data.
It's the man himself! :worship: Thanks for all your contributions to the renix folks, they have been so helpful to me rebuilding this thing.
I tested the 703s with a harness pigtail and a 9v and each one functioned. They also click rhythmically at the same pace when I listened to them with a digital stethescope. I'm currently running the original injectors that were in the Jeep when I bought it. I will keep an eye out for 746s on future junkyard trips.
The only thing stopping me so far from c101 elimination is that I have no soldering experience nor iron. Quick question for you - while trying to locate my two sensor grounds for your Tip #6, I was able to locate the factory splice by the MAP Sensor, but not the splice near the engine near the manifold air sensor as the instructions say. There aren't even any brown/white wires there. Here's a photo of the splice I was able to locate
Thanks again for all the replies - you guys rule.
The Midas that I go to already had a 2.5" Magnaflow high flow catalytic converter sitting on the shelfI've heard there could be some issues if you choose to install it yourself, but I confirmed from my Midas that claim is not true, at least not in my location - doesn't seem to be a concern with my smog shop either. So, if you'd like I can take a photo of the new converter, which has the part number, etc.
A new converter installed at a shop will probably run about 150-220$ including the cat. The place you took for smog, was it only smog or a repair shop. A lot of times shops will re-test for free if you use them to repair your vehicle.
I think the 703 injectors you had in there fouled up the o2 sensor.
When I put the 703s in my 89 and scoped results on my snap on brick, the motor would go into closed loop but quickly reduce the STFT (short term fuel trim)
values to the point of Open Loop
The 703s dump too much fuel for the Renix to handle.
If you had them in for a while they probably messed up your cat converter too.
Look on Ebay for a Snap on MT 2500 .
Its they only way to check your Loop Status and other data
I noticed that as well. Yours passed after install?A direct fit, CA approved CAT is in stock at RockAuto for $157. I put one on my 88 last year when it failed.
Perhaps the "new" injectors are bad?
Volvo 746s work great in the Renix Jeeps.
NEVER a bad idea to eliminate the c101.
