Flash
- Evanston Wy
Sorry, post # 172, shows his spec.....I looked at his post count instead of the post #:twak:
Flash
Flash
XJoshua said:Deck height + compressed head gasket thickness = quench
FWIW, My final numbers are in Colmn IIIXJoshua said:Im going to get a quote on decking, piston cc and balancing. Ill ask for a compression of 9.3:1 so I can run 91octane. Hopefully I can still use the .045 headgasket.
So yea I guess Ill read some more articles while its gone and get my intake setup done.
alex22 said:Next, I saw that the issue of the cams going south in a hurry. It seems like it was droped without a definitive conclusion. Of those who had their cam go bad
alex22 said:I am planing on building my own 4.6 stroker so I spent the last few days reading through this thread.
I saw that the issue of the cams going south in a hurry. It seems like it was dropped without a definitive conclusion. Of those who had their cam go bad how many were using a roller lifter and how many were using flat tappet lifters. also were you using a synthetic oil? The reason I ask is because synthetic oil in a flat tappet engine will cause big problems.
