dbswede
NAXJA Member # 1516
- colorado springs
4.88's but remember 35's are a harsh ride...Its been a long time since this jeep rode like car...........gearing wise its good with a man 5 speed.
dbswede said:I also think that tall tails are coming into play with mileage above 17 ish
cal said:If you drive like you're trying to get 22 mpg, and your rig is tuned well, good o2 sensor and proper gearing, you can get 22 mpg.
Jes said:Haveing a well tuned engine and the proper gearing makes a huge difference in mileage.
TRAILREADYXJ said:If you can, do the full axle build first, but that's really just to save time and labor. It would be easier to install the lockers at the same time you setup the gears. Lockers and 31s can get you through some stuff you couldn't do open on 35s, granted it can work the other way around as well...
You say you have a light foot, so depending on the terrain, you could probably hold off on the alloy shafts for now... Just make sure you carry spares!!! I have broken a couple stock D30 shafts locked on 33s, but both were fairly extreme situations. You WILL want/need alloys eventually, so go ahead and get them if your budget allows.
