Armyan4k
- BROOKLYN NY
guys you think 32" mud tires not so good to drive around in Brooklyn whare thare is no mud
toast said:Would telling you that I plan on a re-gear make you feel better???
stock gearing and a 5 spd is OK with an auto tranny i would gear a little lower...that way the trans does not work so hard...for now it is ok...in the future. not so muchtkjeeper said:Guys I do have a tranny cooler and I understand that it's not ideal to run 33s on stock gearing but is it really causing that much damage? I believe its better for trail running but my 33s are pretty streety and the tranny is not shifting in and out of od. I plan on the gear change but if you folks really think it is causing serious "damage", I trust this forum. I don't want opinions tho, I would like facts. Tranny/engine experts to explain exactly why. I am probably gonna change back to the 31's for the summer just to be safe but I really would like some solid feedback on this. Thanks guys.
ChrisRFewell said:stock gearing and a 5 spd is OK with an auto tranny i would gear a little lower...that way the trans does not work so hard...for now it is ok...in the future. not so much
cal said:ColoradoRaptor said:I have really good brakes and draft RV's a lot.![]()
good brakes on a cherokee? not buying that:huh:
FlexdXJ said:good brakes on a cherokee? not buying that:huh:
BRADFORDXJ said:Not so sure about that one, I had a 93 5spd with 31's and stck gears...gutless and 5th gear was useless, I now have a 96 auto with 31's and is much better. I get loose without trying on dry pavement still not what I want but night and day difference between the 5spd.
89xj said:x2, i think he has it backwards
toast said:indeed I do!
Whats left of the first XJ..
Currently building...
tayman said:I concur!
but I probably would have done a rear axle swap by that point.... and gearing.
Chris @ GATR said:My DD is on 37's.
