3-link in an a nut shell?
bics90xj
After a LOT of reading here is what I have come up with. Upper bracket with 3 adjustment holes @ 7,8,9 in. of link seperation. Rear brackets built in to custom trans x-member also 3 holes of adjustment 5,6,7 in of seperation. Links should end up between 36-40 in. Track bar as long as possible. Please let me know what you think of these specs. Want to to do this correct the first time so pie up with coments.
Easier said than done. :D
You don't need all that adjustability in it. A couple holes on one end of the upper would be sufficient. The arms are long enough that the angles don't matter much. The hard part is getting it to fit, and making everything strong enough.
