child9
- Austin, TX
![JeepEngineswap22016.jpg](/proxy.php?image=http%3A%2F%2Fi54.photobucket.com%2Falbums%2Fg93%2Fckassem%2FXJ%2520Jeep%2520Cherokee%2FJeepEngineswap22016.jpg&hash=43cf81901e7a73511a6c7cbe876ab1b2)
![JeepEngineswap22023.jpg](/proxy.php?image=http%3A%2F%2Fi54.photobucket.com%2Falbums%2Fg93%2Fckassem%2FXJ%2520Jeep%2520Cherokee%2FJeepEngineswap22023.jpg&hash=64ee9397e4805548bf302be0f1f083e0)
The transmission bolts right into place on the stock cross member. There is about 2" all around the head and block leading into the tunnel. I have about 2.5" of clearance from valve cover to hood. Fitment couldn't be better. Wiring harness to ECU easily and cleanly reaches to the stock Jeep ecu location. There is a ton of room on the driver's side to relocate the carbon canister and the radiator overflow bottles to make room for the turbo on the other.
Fuel system: It was discussed today that the Jeep doesn't have a 1:1 fuel pressure regulated system. When the pump is pulled and the Walbro put in the normal return will be disabled and a return line will need to be run to the tank in order for the 2J fuel injection system to operate properly.
A rear sump oil pan is needed. The very corner of the diff, the bolts for adjusting the front alignment, and the panhard bar all want to crash into the front sump oil pan. Axle will if it goes up to much, though it should be fine if you have bump stops.
I bought a lower pitman arm for like $70... it's for Cherokees w/ a 4" lift or so... has anyone by chance tried one on a non-lifted Jeep? I am wondering if it will affect the steering geometry in a bad way. Doesn't seem like it should, but I dunno. I disconnected the panhard bar and the steering damper and was able to get the steering arm reconnected so I can move the Jeep. Are there different shaped panhard bars?
