2 stock dana 30 long side axle shafts
cheapcherokee93
<----boat-manche
Guadalahabra, CA
i have 2 stock factory dana 30 axle shafts complete with stub shafts and u joints. not sure if its the bigger joint but they are non-abs, no tone ring. u joints seem to be in decent shape.
$20 each
located in La Habra but can also pick up at my work in Santa Fe Springs
Do you by chance know the year of axle these came from?
one came from a 90 and the other i believe was from a 2001
IF this is true, the later one will have larger joint, regardless of ABS. Early one will have the smaller joint.
Are you attending so cal fest?
