YEp, XJ was lifted. In 2003 I took it back to stock and sold off most of the lift parts, including the upgraded axles I had.
Replacement axles are a '00 8.25 and a 91 HpD30. Reason for the older axle up front is I knew the history of it. It came off my mom's 91 so rather than play russian roulette with a junkyard axle I opted to go that route with it.
I had Hillside 4x4 do the shift fork dealio last year right before all the snow started flying and 4x worked just great, street tires not so much, but it got the job done.
When I did the swap back to stock I went lift part for new stock part as much as possible. In instances where I could not secure a stock part I picked up aftermarket.
As the Jeep was and always has been my DD I made a hardcore effort to get the best parts I could at the time so that the reassembly was done correctly. I spent 7 days doing the swap just to make sure that time was taken to do it right.
That's why it still has the SYE/HD Driveshaft and adj. UCAs. I was not up for swapping out a t-case and the driveshaft was just right to fit. Only UCAs I oculd find back then were trashed stock ones so I simply adjusted them to work with the stock height and away I went.
As far as the missing vac ball...new bumper and fender and apparently the shop forgot to put it back
Jeep was parked, truck side swipped it and that is what caused the replacement. That was right about a year ago, if I look I can probably find the paperwork so that any potential buyer can see what was fixed, but it was pass fender, front facia and front bumper.
