8Cherokee9
- Front Royal, Va (Northern Va.)
(posted this here 'cause I am not able to post in the for sale section?)
1993 Jeep Cherokee
12x,xxx miles
8” Suspension Lift
35” Truxxus MT’s
15x10 A/R Aluminum Rims
4:56 Yukon Gears Front & Rear
8.25 8.25 rear axle (29 spline) shock mounts welded flush with axle tube
Richmond Gear Lockers Front & Rear
Rusty’s Engine/Transmission Skid Plate
Rusty’s Transfer Case Skid Plate
Rusty’s Rock Hard 1” Drop Crossmember
Rusty’s Metal Tail Light Housings with LED lights
Rock Krawler Steering (Beefy tie rod & drag ling with heim joints)
Ryan’s Fab Front (With 2 driving lights mounted) & Rear Bumpers
Homebrew Rock Rails
Cold Air Intake
Flowmaster 40 Series Muffler & High Flow Cat
Mopar Header
Cargo Basket With 2 Hella 500’s Mounted (also holds full sized spare)
Dash Mounted CB with Firestick Antenna
The Jeep runs great! Not the prettiest but it doesn't look bad either. Interior is complete and the seats are in good shape! The carpet is a little dirty but well positioned floor mats do the trick! The front tires are not to bad, probably under half though, but the rear are almost there as far as needing replaced. The Jeep does not smoke on start up and has good oil pressure.I am asking $4000. I am not looking for any trades. If you would like any additional information just ask and I will tell you can email or call at 540-664-6763.
1993 Jeep Cherokee
12x,xxx miles
8” Suspension Lift
35” Truxxus MT’s
Homebrew Rock Rails
Cold Air Intake
Mopar Header
![Img5225.jpg](/proxy.php?image=http%3A%2F%2Fi62.photobucket.com%2Falbums%2Fh82%2F8cherokee9%2FImg5225.jpg&hash=e299bf8910bd2745af7f58ce6347203e)
![img1234268411036.jpg](/proxy.php?image=http%3A%2F%2Fi62.photobucket.com%2Falbums%2Fh82%2F8cherokee9%2Fimg1234268411036.jpg&hash=400a3b3154a1017399f6761233406a42)
![img1234268408218.jpg](/proxy.php?image=http%3A%2F%2Fi62.photobucket.com%2Falbums%2Fh82%2F8cherokee9%2Fimg1234268408218.jpg&hash=23bdd363b1120123224087fb4822eb51)
![img1234268410254.jpg](/proxy.php?image=http%3A%2F%2Fi62.photobucket.com%2Falbums%2Fh82%2F8cherokee9%2Fimg1234268410254.jpg&hash=de75340b638287e94eddb7ccc8024b78)
