90NHXJ
- Milton, NH
02 Grand Cherokee. 4.0. What is the rear axle on this. It looks like a 35 but when I pulled the dif cover it doesn't seem to have a c clip. Just by visual. I didn't try removing the rod in the middle of the spider gears. There was already a gap between the axle and the rod and I wasn't able to close it by pushing the axle inwards. On a c clip I believe you would be able to push it in a bit to expose the c clip. The rod would prevent the axle from moving in to expose the clip until you remove the little set screw and pull the rod.
Whole point is I have a driver side axle shaft leak on the rear dripping all over the brakes. How do you replace this seal if it's not a c clip style. And please educate me correctly if it is in fact a c clip and I'm just being plain dumb. Thanks -
