jeeptec
- atascadero california
I'm fighting some bump steer since I raised my XJ 1 more inch. Total of about 5 or so. I'm running the Synergy suspension track bar kit and brace with drop pitman arm. From what I can tell the the track bat and steering are on the same plane. I'm still running the Y linkage with the heavy duty drag link adjuster and tie rod sleeve. I've noticed that the drag lying from the pitman arm to right knuckle is at a pretty good steep angle. I was looking at the JCR 1 ton steering kit . It is similar in design as the later Ram trucks. The Rams have had a Y linkage and went to a T style around 2008. I'm wondering if this would help.
Sent from my iPad using Tapatalk
![cbb1f569c4ac962f02027b0715ad47a6.jpg](/proxy.php?image=http%3A%2F%2Fuploads.tapatalk-cdn.com%2F20160802%2Fcbb1f569c4ac962f02027b0715ad47a6.jpg&hash=eb75a0a4c26f5d568ce98845e9940bde)
![d91ac9efb86cafcc42569028b6b23042.jpg](/proxy.php?image=http%3A%2F%2Fuploads.tapatalk-cdn.com%2F20160802%2Fd91ac9efb86cafcc42569028b6b23042.jpg&hash=316da98fd022e3d599b4b731d69cfa7c)
