Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Other Technical Forums > Jeep Street and Performance
Jeep Street and Performance Do you like to go fast in your Jeep?
Old March 30th, 2011, 17:58
Talyn's Avatar
Talyn Talyn is offline
Some fun projects I have been working on
Figured I would post a few other project I have been working on for the XJ.
First I made a gauge bezel/overlay. I had been thinking about doing something like this for a while since I have access to a router at work. Previous I had one of the cheap stainless 2d ones found on ebay. The final nudge to get me going came from a friend in Canada. I purchased a gauge cluster for test fitting and scanned it in to my computer. From there I brought it into illustrator and drew the shapes needed. After several test cuts and alterations in Illustrator I came up with what you see below. It is 6061 T6 aluminum, sandblasted then hard anodized grey. The text and symbols were etched on the laser at work. The speedo and tach have 45* bevel and the other gauges are straight cut. 3 different designs were made. This project went well over a year in production. It is pure bling but it came out better than expected.
The second one I was working on is a multigauge. I wanted some extra gauges, but didn't see anything I liked. Just purchasing something would have been too expensive, too many and have taken up too much room. When you start adding crap to the interior you realize how limited the space you have to work with is. The gauge will display engine vacuum, oil pressure, oil temp, and transmission temp. I can also later add other sensors and features to it if I want to. It is based on an Arduino Duemilanove (http://arduino.cc/en/). The Duemilanove has 6 analog inputs and 14 digital input/outputs (http://arduino.cc/en/Main/ArduinoBoardDiecimila). It is programmed in C. Amazingly I actually remembered how to program in C. The display is a 16x2 trans-reflective LCD amber in color. It is encased in a 4 part plexi housing; clear back, clear mid section, black front with clear lens. The housing was also cut on the router. The Arduino and its power supply)it takes 7-12v for input) are mounted behind the glove box. For temperature I used ISSPro sensors, oil I used an Autometer sensor, and for vacuum I will tie into the factory MAP sensor. I normal operation it will display oil temp, oil pressure, transmission temp, and vacuum. Should the oil pressure drop too low, the oil temp get to high, or the transmission temp too high it will sound an alarm (really annoying) and display the out of spec parameter (which can be seen in the images). I used a RAM mount to attach it to the mirror arm. The oil pressure sensor is at the back of the block where the stock sensor has been relocated to. The oil temp sensor is placed after the oil filter where the stock oil pressure sensor use to be. The transmission temp sensor will be placed after the hot hard line and before the soft line for the cooler that I installed earlier.
The last project is a more concealer radar detector. A few years ago I had made a concealed mount for my Valentine 1 on the over head console out of fiberglass, as seen below, and used its remote display mounted on the dash. I was unhappy with a) where the remote display was mounted (low right of the gauge cluster) and the fact that the Velcro that was holding it on kept falling off. I decided to mount it behind the dash it self. I used the router to cut a hole in the dash panel to the upper right of the gauge cluster then cut a lexan panel to fit flush in the hole in that hole. I also put some tint on the back of the lexan to disguise it further when off. The display was converted from all red leds to different color leds indication signal strength and the band. The mute/function button was installed on the dash below the toggle switch for the Lightforce lights I installed years ago. Now I have a completely concealer and out of the way radar detector.
Talyn's Avatar
Re: Some fun projects I have been working on
I am also working on a headlight leveling system found on the European XJs. I have the switch installed and wired but have not yet installed teh leveling servos and brackets.
I still would like to cut some new pedals on the router and a battery hold down. Maybe some other stuff if I have time.
One last image or everything:
Old March 30th, 2011, 18:24
ehall's Avatar
ehall ehall is offline
that's some nice work
my '91 beater rebuild
Old March 30th, 2011, 18:34
Boveevil Boveevil is offline
Very nice!
Old March 30th, 2011, 19:23
oldmantompkins oldmantompkins is offline
Did your V1 come with the different colors or did you change them yourself? Looks great.
Old March 30th, 2011, 19:45
Talyn's Avatar
I had them changed a while ago before this project. They came with all red. I was not that good at soldering small bits at that time.
Old March 30th, 2011, 20:26
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
beautiful!
I've been intending to install trans temp/pressure sensors for a while now. Maybe when it warms up a little bit more...
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old March 30th, 2011, 20:44
DanMan2k06 DanMan2k06 is offline
Dude hit me up if you can repoduce that bezel. I would definitely pay some good dollhairs for one.
Old March 30th, 2011, 21:39
Boostwerks.com's Avatar
Boostwerks.com Boostwerks.com is offline
NAXJA Supporting Vendor
Very nice! That bezel looks good.
99 XJ Sport Build Thread:
http://www.naxja.org/forum/showthread.php?t=1059015
Check out our website!
www.BoostwerksEngineering.com
Old March 30th, 2011, 22:42
gradon's Avatar
gradon gradon is offline
Oh VA and their stupid no radar detector law
Nice location.
Old March 30th, 2011, 23:29
urban yan urban yan is offline
We're friends? When did that happen? lol
Might as well post my bezel as well since the secret's out about my supercharger. It might help you rack up some sales.
Old March 31st, 2011, 07:17
hubs97xj's Avatar
hubs97xj hubs97xj is offline
Interesting; I saw a similar bezel on ebay briefly; I couldn't find anything else like it, and then two turn up, although slightly different. Both bezels look great.
Old March 31st, 2011, 07:46
There were a few designs, and I believe Talyn listed them on ebay a few months ago.
Old March 31st, 2011, 08:06
nosdujshsdl's Avatar
nosdujshsdl nosdujshsdl is offline
I want that multi gauge, just awesome.
Old March 31st, 2011, 11:25
Talyn's Avatar
That is correct. I had a brushed one and a glass beaded one on ebay. Both were bare aluminum.
Rate This Thread:
MY NEW PROJECTS a1collier Non-Tech / Off Topic 6 January 28th, 2010 18:30
Just one of my little projects. Hammered North Atlantic Chapter 25 January 16th, 2009 14:28
Two New Projects Mike L SoCal Chapter 13 November 1st, 2008 18:45
90 MJ Too many projects indyjeepnut For Sale: Private Party Only. XJ ITEMS ONLY 8 May 16th, 2006 13:10
A few more projects done Incredible Hulk Modified Tech Discussion 3 March 6th, 2004 08:57
