Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Colorado Chapter > Other Rides and Builds
Other Rides and Builds A place for the discussion of Colorado "Side Projects"
  #331
Old November 12th, 2016, 19:35
riverfever's Avatar
riverfever riverfever is offline
Re: My Turn
I have new clip on bars coming on Monday and they are so much nicer than the current ones. I also decided to start sanding and polishing the top clamp to match the other polished aluminum bits. I filed all the casting marks off as best as possible (there's a few that are gonna have to stay just because they are in such a bad spot). It's sanded to 120 now. I always find areas that need more attention when I step up to the next grit but I'll start 220 tomorrow.
Old November 19th, 2016, 21:44
riverfever's Avatar
Re: My Turn
These are the new turn signals.
Got the new bars installed today along with the m-switches. I need to order a new upper brake line. 15 rolls of 25' wire are on the way.
Old November 25th, 2016, 20:02
riverfever's Avatar
Re: My Turn
Finally got the top clamp finished up. There's a few spots I'm not totally happy with but it's better than it was.
New mirrors and grips were installed today.
New master cylinder will be here in a few days and then I'll get new brake line made. I'm also looking at a snazzy new clutch lever but I'm still thinking about that.
All the wiring showed up tonight.
Old December 9th, 2016, 21:00
riverfever's Avatar
Re: My Turn
Practiced crimping these open barrel terminals that I'll be using and I think I figured them out now.
I've also been working on restoring this old Falstaff sign and finally finished. This belonged to Heather's grandmother and it used to hang in a bar she owned in downtown St. Louis in the 1940's. Got it hung tonight.
Also got a new clutch lever from Pro Taper. This has a bearing in the pivot and really makes a huge difference. With a new cable, it's a pleasure to use now.
Old December 14th, 2016, 18:29
SteveT SteveT is offline
Re: My Turn
Is that a self portrait to the left of the Falstaff sign?
Sent from my SM-N920P using Tapatalk
Old December 14th, 2016, 19:37
riverfever's Avatar
Re: My Turn
It is. A student made it for me for a project in art class years ago. Kinda cool but, every once in a while, I get the feeling I'm being watched while working on something in the garage. Sometimes it scares the shat out of me.
Old December 23rd, 2016, 19:40
riverfever's Avatar
Re: My Turn
Minor but important update. What's been holding up this party is that two pieces needed to be made. One is a panel that will hold all of the new electronics and live under the left side cover (where all the stock electrics are located). It's not done in this pic but is now. The starter solenoid will mount to the right of the M Unit and the regulator/rectifier will mount on the backside of the panel and to the rear of the bike. Side cover will fit on and nobody will know what's going on until it's removed.
Next was where to mount the M Lock. I wanted it under the side cover but was worried it wouldn't read the fob through the plastic. Thought about drilling some holes in the cover to help but didn't want holes. Thought about doing a mount in the end of the bar but I use bar end mirrors. So...in the end I decided to put it in the stock location which is down by the #1 header on a tab located on the frame. Next was to figure out exactly how to do it. A good friend helped me and this piece started off as a solid 1.5" by 3.25" alloy bar.
Wires for the M Lock will come out the back, travel up the frame to the neck and then down the backbone to the M Unit. We were going to weld an L bracket onto this cylinder and use that to mount it to the frame tab but then decided it was easier to simply drill the cylinder, tap it and use a 6mm bolt to secure it. This piece doesn't ever get touched so one bolt should be enough I hope. I was going to have it anodized black to hide it a bit but I decided to polish it. People that know these bikes will notice that it's unusual and the polish will show it off a bit.
Old January 8th, 2017, 19:05
riverfever's Avatar
Re: My Turn
I finally dove into the wiring on this project. Today I got the bars drilled, both M-Buttons wired up and the wires run through the bars. Here's some pics.
Here's the left side.
Inside of the right side button.
Right side done.
I just brought each loom down the opposite side of the backbone and that's where I stopped for today. I have an idea to clean up the ground location from where they normally are stock and I'm looking to do it right about this location. I'll take all the green ground wires out of both looms, deal with them right here (on each side) and then run the rest of the wires on back to the electrical panel. I will say that I have a whole new appreciation for cars and motorcycles that have very clean custom wiring. It's tedious.
Old February 19th, 2017, 19:56
riverfever's Avatar
Re: My Turn
Haven't updated this in a while. This is how I'm running the wire looms along the back bone and securing them.
Ended the looms just up from the second p clamp on each side and that's where I'm grounding everything. Then continuing the looms and organizing the wiring into input and output wires for the M Unit.
And then moving on back.
At this point I decided to rough wire everything up to the M Unit and make sure that it was working. It was then that I discovered a major problem. The M Lock (this is a sensor the size of a quarter that uses RF technology to read a fob to activate the system) wasn't working. When I got everything I tested it on the bench and it was fine. I assumed it was a problem with the wiring. The sensor uses a ground wire, a wire to battery positive, and a wire to the M Unit. All checked out. I was beginning to think the M Lock was bad. On a whim I decided to remove the knurled alloy cap on the mount and...it worked fine. The cap was covering the outer 1mm of the sensor face and this, apparently, was causing it to not be able to read the fob. So...back to the drawing board. I had to undo two looms of wire on the right side of the frame and figure out a new mount for the sensor.
While I chewed on what to do for a mount I decided to deal with mounting the rear turn signals. My original idea of mounting them to the grab bar wouldn't work so I made some tabs.
Yesterday I decided to make another bracket for the M Lock. I used some angle I had laying around.
At this point, I need to finish painting the new mount and then re-solder the wires for it and put the looms of wire back together. I need to buy a right angle drill tomorrow and install a rivet nut on the bottom of the tube for the seat rail to use as a ground for the rear turns and tail. Then I can continue to bring the wire closer to the M Unit and start tying it all together.
Old February 20th, 2017, 10:17
RedHeep's Avatar
RedHeep RedHeep is offline
NAXJA #1499
My Turn
Zip ties are cheaper.
Old March 1st, 2017, 19:50
riverfever's Avatar
Re: My Turn
Certainly but the grounding points would be sketchy with a zip tie.
Rate This Thread:
What happens when you turn the key to acc? XJRocket OEM Tech Discussion 5 January 3rd, 2009 12:50
Which way does she turn? IntrepidXJ Non-Tech / Off Topic 31 September 27th, 2008 23:14
turn the key and nothing Nuke Proof OEM Tech Discussion 10 August 4th, 2008 19:13
Turn key... Nothing macamon OEM Tech Discussion 10 November 19th, 2006 18:14
Turn signal doesn't turn off montanaman OEM Tech Discussion 6 April 10th, 2006 20:20
