- Torrance, CA
In order to participate on this (and any other) event you must follow the below:
Minimum Equipment Requirements
1: Visibly charged fire extinguisher (BC or ABC type)
2: First Aid Kit
3: Adequate spare tire, jack, and lug wrench*.
4: Safety belts for driver and all passengers.
5: Adequate tow points. Must be of OEM or greater integrity (no three bolt cheap brackets), d-rings, shackels, etc are all good as long as the hook or bumper brackets meet or exceed the OEM kit. Welded tow hooks are never allowed.
6: Snatch strap without metal hooks.
7: Battery must be properly secured.
*Notes*
Rule 3 may be waived at trail leaders discretion.
Safety Rules
Driving under the influence of drugs or alcohol is not permitted.
Safety belt use is mandatory.
Pets should be well-behaved or secured.
Do not exceed the maximum speed limit on all roads, public or private.
Suggested Equipment
In addition to the above list of required equipment the following equipment is recommended.
CB Radio
Extra food & water
Flashlights
Blanket or sleeping bag
These lists may be modified as event staff see fit, notice will be given in the thread title if necessary.
Also be advised that snow is still a possibility in late April. This event will be held regardless of weather. If snow conditions are present the CHP may require snow chains to come to Big Bear, don't get turned around halfway to the event, plan ahead.
2: First Aid Kit
*Notes*
Safety Rules
Suggested Equipment
CB Radio
Extra food & water
Flashlights
