Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Events > Past NAXJA Events > PAST NAXJA EVENTS > NAC Fest 2006
NAC Fest 2006 June 8-10, 2006: Paragon Adventure Park, Hazelton, PA
Old March 31st, 2006, 12:28
Menzenski's Avatar
Menzenski Menzenski is offline
Formerly Mambeu
Some questions on safety equipment
I'm starting to get things together for NAC-fest, and want to make sure of a few things before I spend any more money on my Jeep.
Insurance - I assume the safety inspector will just be making sure that I have proof of insurance. I do, but it's liability only. Is that okay?
Fire extinguisher - Just a basic ABC type, right? Is there a certain size I'm supposed to have, and does it need to be mounted to the Jeep somewhere?
Jack - I hope to have a Hi-Lift before NAC-fest, but if finances don't allow it, will I pass inspection with the stock bottle jack?
Lug wrench - Do I need a separate cross-style lug wrench if I'm bringing a socket set (and small cheater bar)?
Tow strap - I know not to get one with metal hooks, but is there a 'right' kind to get? Length, width, strength rating, et c.
NAC-fest will probably be my first four-wheeling experience, so I really know almost nothing about the equipment required.
  #2
Old March 31st, 2006, 13:42
lobsterdmb's Avatar
lobsterdmb lobsterdmb is offline
Just a Lobster Minion
Re: Some questions on safety equipment
Yes it Is
ABC is fine, best place to mount is right next to the drivers seat in the door jamb
Yes
No, a socket set with cheater bar is fine
20 feet x 2inch wide 10000lb or larger is fine
See answers in Quote. Make sure you have front/rear tow points and have your battery secured. Also a fullsize spare is necessary.
Johnny
Retired President
Support , become a member!
  #3
Old March 31st, 2006, 17:53
Menzenski's Avatar
Formerly Mambeu
I have one front tow hook and two rear tow hooks, a fullsize spare and a secured battery, so it sounds like I only need a fire extinguisher and strap. Thanks!
  #4
Old March 31st, 2006, 18:08
STROKER's Avatar
STROKER STROKER is offline
<-- A Tribute
Location: in my own little world, jus' dunno where it's at
What lobsterdmb said....
STROKER
When we wheelin w/4.6 STROKER Friend of Matt #17
RAUSCH CREEK
Xj in progress
  #5
Old April 2nd, 2006, 16:15
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Having hooks is good, but how are they mounted? Badly mounted is worse than nothing at all.
Rob
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
  #6
Old April 2nd, 2006, 16:29
Menzenski's Avatar
Formerly Mambeu
Rob
They're from 4x4trailhunters.com.
This is my front (sorry about the huge pic):
My back ones aren't mounted quite yet, so this is photo is from the trailhunters web site:
There's a nutstrip inside the framerail and an l-shaped bracket below it, and the hook mounts to the underside of that.
  #7
Old April 3rd, 2006, 06:22
NAXJA Member #920
I have to admit that I've not seen that design before for a front hook mount.
Between the pics and what I read on the vendor's web site, they sound ok to me.
However, since I'm not exactly the most mechanically inclined of folks, perhaps one of the more fabrication-minded folks can chime in here and offer a more experienced opinion? (It's not that I don't trust you, it's that I don't necessarily trust my opinion on something like this just yet)
Rob
1984 Dodge Omni
  #8
Old April 5th, 2006, 20:36
Menzenski's Avatar
Formerly Mambeu
Does anyone else have an opinion on my tow hooks? I don't see how they wouldn't be okay, but if they aren't, I'd rather find out now than during the safety inspection.
And I bought a fire extinguisher, first-aid kit, and tow strap (2"x30', 18,000 lbs) today, so I should be set safety-equipment-wise.
  #9
Old April 6th, 2006, 04:24
STROKER's Avatar
<-- A Tribute
Yep there fine, don't worry.
STROKER
RAUSCH CREEK
Xj in progress
  #10
Old April 6th, 2006, 04:59
LOWTECH LOWTECH is offline
Better then alot of folks
  #11
Old April 6th, 2006, 10:47
Menzenski's Avatar
Formerly Mambeu
Awesome. Thanks guys!
Rate This Thread:
Audio equipment, Lift equipment, and more... darwin For Sale: Private Party Only. XJ ITEMS ONLY 7 February 14th, 2007 22:32
Equipment Check RTicUL8 Non-Tech / Off Topic 11 February 15th, 2006 13:29
Required Equipment Questions/Help BCParker Winterfest 2006 26 February 6th, 2006 18:58
Stereo Equipment......... RockRod For Sale: Private Party Only. XJ ITEMS ONLY 0 January 15th, 2005 15:59
equipment/safety requirements sidriptide Mohawk Madness 2004. Northwest Mass. 0 August 2nd, 2004 20:46
