Go Back   NAXJA Forums -::- North American XJ Association > Land Use / Off Topic and other Forums > Adventure Forum
Adventure Forum A place for outdoor side of your XJ/MJ. Discussions revolve around camping, equipment, and camping trailers. As well as outdoor activities that take off from your XJ/MJ like hiking, geocoaching, and rock climbing. Also the place to discuss tips and hints for the best places to camp off the beaten path.
  #46
Old June 1st, 2019, 19:37
macgyvr's Avatar
macgyvr macgyvr is offline
NAXJA Member #120
Re: My M416 restomod/hole to throw money in
Looking good!
Can't wait to see it soon!
mac 'deadline is coming up' gyvr
MWC President / President
It's always a good time to join or renew your membership!
My idea of a perfect vacation is a road trip through beautiful country. To make it really fun, all that's needed is a modified vehicle, a few close friends, and some serious off-roading. Cole Quinnell - Editor, 4WOR, Dec 99
Old June 2nd, 2019, 06:55
Anak's Avatar
Anak Anak is offline
Stranger
I have got to be missing something...What keeps that shock absorber on that mount?
Baby it's cold outside.
Old June 2nd, 2019, 07:08
RedHeep's Avatar
RedHeep RedHeep is offline
NAXJA #1499
A cotter pin.
You have to push it on pretty hard to get to the pin hole in the stud. I probably exaggerated the problem with my weld but it still works.
Old June 2nd, 2019, 15:28
RedHeep's Avatar
NAXJA #1499
Got the bottom of the tub coated with por-15. Then did the bottom of the frame.
Installed the marker light so I wouldn’t lose them.
Marveled at my lack of welding skills before I painted over them. If you want to hide your ineptitude I recommend por-15.
Then I installed a new pioneer stereo into my wife’s FJ Cruiser because she wanted wireless CarPlay and I wanted vehicle gauges.
And now I pack for a work trip to California. Next weekend we get it rolling.
Old June 3rd, 2019, 10:10
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Originally Posted by RedHeep View Post
Finishing up all the welding today. Had to put pockets in to clear the drain plugs in the tub.
Looks to me like those pockets would allow water to get down inside the frame (considering all the nice work you've done so far to build it, that doesn't seem desirable).
If you're not planning on closing those off, are you going to use one of those long-wanded sprayers or something to coat the inside of the frame to prevent rust from the inside?
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old June 3rd, 2019, 12:58
RedHeep's Avatar
NAXJA #1499
I thought about doing the extra fab to completely close them off, but the top of the crossmember is real snug to the bottom of the tub. I probably should have done it but I figure that by the time water gets in there and rusts from the inside out it will be my kid’s problem.
I’ve been trying to balance the perfection vs good enough argument and I’m just at the point where it needs to get done and on the road.
Old June 4th, 2019, 11:09
NAXJA Member #920
Fair enough.
Besides, like I said, they have these cans that have a big long wand with 360-degree nozzle that you snake into the frame so you can paint the insides - here's one: https://www.eastwood.com/eastwood-in...z-aerosol.html
1984 Dodge Omni
Old June 5th, 2019, 12:27
RedHeep's Avatar
NAXJA #1499
That’s a good idea. Those two holes are only in those crossmembers.
Old June 5th, 2019, 16:30
NAXJA Member #920
Glad to have been of service then!
1984 Dodge Omni
Old June 8th, 2019, 14:32
RedHeep's Avatar
NAXJA #1499
Lots of progress the last week or so. Spent the week in San Diego for work so lots of stuff was waiting for me when I got home.
Picked up a legit m100 canvas reproduction top.
Got the leaf spring brackets cleaned and painted and then mounted for the last time.
Late last night after a lot of painting I hung the leaf springs and axle.
Old June 8th, 2019, 14:41
RedHeep's Avatar
NAXJA #1499
This morning I was ready to see if the thing was going to be a trailer. Mounted the wheels and pushed it outside. Surprisingly everything fits.
Then back to the grinder. Got the landing leg and the safety chains cleaned up.
Two trips to TSC (I should buy stock) because military safety hooks are too thick for regular end links. Decided on some new chain to save me some time.
And finally, no more chassis paint. Bonus points if you can name the WF raffle prize in the picture.
I have to drive my oldest to and from summer camp the next two weekends and I have to go to NM for work in two weeks so the thrash is on to get the wiring and tub painting done. My hvlp gun, mixing kit and respirator came today and the OD paint will be here on Tuesday.
I haven’t decided on diy bedliner or having someone do it but I might just drive it to linex to save time.
Old June 8th, 2019, 20:38
macgyvr's Avatar
NAXJA Member #120
The orange hammer is a WF raffle prize...
What’s a late night for you?
mac ‘past 11? :flipoff2:’ gyvr
Old June 9th, 2019, 16:06
RedHeep's Avatar
NAXJA #1499
8:30
Red ‘Lets compare records sometime’ heep
:flipoffsmiley
Old June 17th, 2019, 13:52
RedHeep's Avatar
NAXJA #1499
Got some wiring done.
Final connections inside the tongue box.
Then out to the tongue with the vehicle connector.
Discovered that my m416 hub on a m100 axle swap is not plug and play. The backing plates and brakes are the same but the m100 spindle is 1/4” longer between the bearing surfaces. The bearings are the same bore size so I’m going to run an 1/8” inner spacer on the spindle to bring the hub out to the right place on the spindle. I checked the bearings and they run where they’re supposed to if we add a little room behind the inner bearing.
Old June 17th, 2019, 14:01
RedHeep's Avatar
NAXJA #1499
Nate and I couldn’t find any creative solutions on the internet, just a lot of they’re not compatible. I’m hoping this is an easy fix and gives people an option if they have bad m100 hubs. There are no reproduction hubs anywhere but there’s still lots of m416 parts in the surplus yards.
It will take a little dremel work, but these washers were 10 for $7 on amazon and they have the 1.625 inner diameter for the spindle.
Rate This Thread:
WTT Restomod 1968 Chevrolet C10 for XJ or TJ spazzyfry123 SEC For Sale / Wanted Forum 19 July 25th, 2011 12:47
M416 Trailer IH8RDS Non-Tech / Off Topic 79 November 11th, 2008 12:59
M416 wndrlst For Sale: Private Party Only. XJ ITEMS ONLY 0 December 31st, 2006 12:03
7.75" Drop shackles, Hole to Hole boise49ers Modified Tech Discussion 9 December 16th, 2004 10:00
