Old September 19th, 2006, 17:07
1985xjlaredo's Avatar
1985xjlaredo 1985xjlaredo is offline
Mopar 360 In XJ
I was wondering if anyone has ever done this or anything like it.
I am wanting to put this engine in My 1985 XJ Laredo.
http://www.jegs.com/webapp/wcs/stores/servlet/CategoryDisplay?storeId=10001&catalogId=10002&cata logIdentifier=&categoryId=20261&parentCategoryId=1 0763
I have a TC904 Tranny but I also dont know if it will bolt up to the 360 since it is now bolt to a 2.8L chevy 60degree V-6. If anyone has any info Please post
Old September 19th, 2006, 17:37
RichP's Avatar
RichP RichP is offline
Re: Mopar 360 In XJ
Well, the 318 was an option and the 360 did come in the ZJ for 2 years at least so it's dooable...
Old September 19th, 2006, 17:50
Blue XJ's Avatar
Blue XJ Blue XJ is offline
Re: Mopar 360 In XJ
The 318 was never an option for an XJ.
Old September 19th, 2006, 17:51
Root Moose's Avatar
Root Moose Root Moose is offline
Re: Mopar 360 In XJ
I'm pretty sure Rich meant in the ZJ for both engines.
Old September 19th, 2006, 17:54
dallas xjs's Avatar
dallas xjs dallas xjs is offline
Re: Mopar 360 In XJ
at $4,999.99 why would you wont THAT engine??i understand it would bring the value up on your jeep,but $4,999.99
Old September 19th, 2006, 18:03
Kittrell's Avatar
Kittrell Kittrell is offline
Re: Mopar 360 In XJ
Originally Posted by dallas xjs
I understand it would bring the value up on your jeep
Maybe $500 if he is lucky............
Old September 19th, 2006, 20:16
RichP's Avatar
Re: Mopar 360 In XJ
Yup.
Old September 19th, 2006, 21:28
Re: Mopar 360 In XJ
I dont want "That" engine I just want something comparable built for me at a local shop.
Has anyone ever done this or something like it in a 4x4 XJ. I have seen street XJ's with v-8's but not a 4x4.
Old September 19th, 2006, 21:39
WB9YZU WB9YZU is offline
NAXJA Forum Supporter
Re: Mopar 360 In XJ
It will not bolt to the TF904 you presently have in your 85.
The problem is that the 60deg GM V6 does not have the same bolt pattern as the small block MOPAR engines. That bell housing is not even the same as a SBC!
Your best bet might be to find a trashed ZJ and swap the drivetrain. My bet is it won't be worth it unless it is cheap!
If you are looking to replace the 2.8L which is in your truck, I believe a 3.1 or a 3.4L 60deg engine will fit nicely and give more power. On the same yard raid, perhaps you can also score a FI computer/harness and make a secondary inprovement, reliability.
GM also sells a NEW 2.8L replacement engine (IIRC it is actually a 3.1L) for around $2K. Search the Forum for more results as tis is not the first time this has been asked and you may find more details
If you do decide/manage to get a V8 hooked to that poor TF904, purchase a rebuild kit from MOPAR, and find a machinist as you will want to upgrade the clutch pack to a 5 clutch pack which requires machining of the drum.
Ron
Old September 19th, 2006, 22:27
Oatmeal Oatmeal is offline
Re: Mopar 360 In XJ
This is probably of no help to you but, way back when 4WD Sport Utility Magazine first came out, it was called 4WD Action Magazine and the owner (Tom Mc Mullen) of the publishing company who, along with his wife (Deana), perished in an airplane crash, was building a project XJ and they stuffed a 360 into it and it also sat on (unheard of at the time) 35s. So, if you could get a hold of some old issues (I'm talking about way back in '87 or '88) they had a complete step by step of the build up spread out over several issues. So.....yes it is possible. If I remember correctly, the guys from Tomken Machine might have been involved with the project---------Hans
Old September 19th, 2006, 23:28
5-90's Avatar
5-90 5-90 is offline
Re: Mopar 360 In XJ
Why MOPAR? Do an AMC360!
If I was going to do a MOPAR engine, I'd go for heavy "unique" factor and do something like a 426 Hemi...
5-90
Old September 19th, 2006, 23:48
ROBZ95Xj's Avatar
ROBZ95Xj ROBZ95Xj is offline
Re: Mopar 360 In XJ
5-90
sidriptide has me goin on a 340 swap
Old September 20th, 2006, 01:04
5-90's Avatar
Re: Mopar 360 In XJ
Hell, if you want something really unique, see if you can track down an AMC327 and use that... They did exist - they were marketed, as I recall, as the "Vigilante" engine...
5-90
Old September 20th, 2006, 05:14
Kittrell's Avatar
Re: Mopar 360 In XJ
5-90
Even more so, go with the 390, if you can find one......
Old September 20th, 2006, 07:09
djblade311's Avatar
djblade311 djblade311 is offline
NAXJA Member # 1474
Re: Mopar 360 In XJ
I've seen a 360 stuffed in an XJ but I have no idea what they did onthe transmission and tcase. I remember the guy talked about the wiring hell. He also had to go with Flexlite cooling fans to allow room for block. And quite even an electric water pump....
DJ Josh Blade
I Roll on the Wheels of Steel..wiki
10-11 SoCal Chapter President
5.7L Mopar V8 (non-hemi) Project_MudXJ Modified Tech Discussion 16 January 2nd, 2006 19:15
mopar parts XJsaabTech Jeep Street and Performance 8 June 28th, 2005 05:28
Mopar Performance ECU CW Wanted: Private Party Only 0 September 20th, 2004 14:06
mopar 8.75 questions offroadman83 Modified Tech Discussion 7 January 17th, 2004 17:10
Keep an eye out - Mopar Performance ECU #'s lunghd Jeep Street and Performance 2 December 19th, 2003 17:03
