SurfXJSnow
- Charlottesville, VA
Anyone had success with this? I've been reading up on it and it seems pretty straight forward. Just stick small pins into the meaty part of the tread in the middle of the front of the tire on both sides, measure between them, roll jeep back so pins are on backside of tire and measure, then toe in 1/8" more than you're reading on the backside... Loosen tre's and turn and measure till you're aligned.
Anyone had success with this? I'm sick of paying some shop 80 bux everytime I need an alignment just to loosen 2 bolts and turn my tie rod a few times.
