Old February 28th, 2007, 19:17
wrenchntech wrenchntech is offline
8.8 swap info please
ok guys ive looked at other posts. this is what i have , 88 xj with a dana 35 RE 5.5 lift and slipyok eleminator with a tom woods driveshaft. i was lookin into swapping to either a 8.25 or a ford explorer 8.8. i know from reading that the 8.8 is alot stronger than the 8.25, i know ill have to strip the8.8 and weld on new mounts, im fine with that. being that the explore housing is bigger with have any issues with my driveshaft length. i know ill need a driveshaft adaptor too right.
Old February 28th, 2007, 19:35
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
Re: 8.8 swap info please
I just bought an 8.8 for mine, haven't put it in yet, but I decided now is the time for an SYE as well. an XJ front driveshaft will be more than long enough with the 8.8.
John V.
RRC VP
01 XJ Sport 2 door 5spd/4WD- 4" lift, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
Old February 28th, 2007, 20:04
yeah but will the my tom woods driveshaft be a problem. i may just get the 8.25 and put some axles in it for strentgh
Old February 28th, 2007, 20:16
sandyeggoxj's Avatar
sandyeggoxj sandyeggoxj is offline
Depends on the length of the shaft. I was able to reuse mine TW shaft when I went from a turdy-five to a 44. Just measure the length of the pinion on the 8.8 and compare it to the length on the 35.
The other thing to watch out for is size of the u-joint. I had to get a combo u-joint because my 35 had the larger size. Don't remember the numbers, but it was sort of a pain trying to find one in town.
Old February 28th, 2007, 20:42
jpcherokeekid's Avatar
jpcherokeekid jpcherokeekid is offline
[quote=sandyeggoxj] Just measure the length of the pinion on the 8.8 and compare it to the length on the 35.quote]
You forgot to metion that the axle is also offset to the pasenger side by 2 3/16 from center compared to the 3/4 offset of the d35, that will affect the overall length by quite a bit.
You can get 80% of the benefits for 20% of the effort/cash. The last 20% will cost you the 80% of the money
Old February 28th, 2007, 21:28
Tazjig's Avatar
Tazjig Tazjig is offline
what length is you TW driveshaft, i have an 8.8 with a sye and 6.5" lift and a front driveshaft just works. It is 34" ujoint to ujoint.
Old March 1st, 2007, 02:21
the length of the sye matters also... i have the tera extreme short shaft and my ds is over 3 inches longer. bad choice on my part to go with that kit, but that is a different story. The main thing is to just measure the length and then get a ds, or find someone running the same setup and see how long their ds is u-joint to u-joint.
Old March 1st, 2007, 02:25
BlueGerbil's Avatar
BlueGerbil BlueGerbil is offline
Im sitting at 7.5" and my Woody shaft works fine, after we swapped the 8.8 in.
Old March 1st, 2007, 08:37
Tazjig's Avatar
not exactly a bad idea to go with the shorty sye, its actually a good idea because it helps your driveline angle a nice bit, the down side is a longer shaft.
Old March 1st, 2007, 09:00
The bummer is that I now have an electronic tone ring style speedo sensor. So to calibrate I need buy a conversion box, not just a $10 gear...
Old March 1st, 2007, 09:15
Tazjig's Avatar
haha, ya i guess that would definately be a downside. Just do what i do, roll with no speedo, god darn cable.
Old March 1st, 2007, 09:29
Im just adding 10% or so right now. I always get a little nervous when a cop follows me, but hey, who cares. A $100 ticket is cheaper than a $200 box...
swap info pls sbxoxj Modified Tech Discussion 4 September 22nd, 2006 14:11
2.8 to 3.4 swap info. Chris85xj Modified Tech Discussion 2 May 10th, 2006 19:59
I Need some info on a H.O. Swap jeepboy381 Modified Tech Discussion 0 April 28th, 2005 15:22
doing swap ,need info,PLEASE REPLY!! outlander Modified Tech Discussion 1 November 12th, 2004 17:15
Swap Info Needed Dan Starc OEM Tech Discussion 5 November 10th, 2004 09:38
