Old September 18th, 2019, 02:41
Down under Down under is offline
CPS easy access
I had a brain fart idea when I took the head of my XJ, I noticed how easy was to get to the sensor..... get your hand al over it!
So i "was" Going to cut a small access peice out o f the firewall.
Just big enough to get your hand in from inside the cab.
And fab up a nice plate over it.
In Australia, it seems to be possible, as it's up under the passenger side.
And appears possible?
I got the head back that day, and bolted it up before I remembered. Doh!
Any thoughts on it?
Old September 18th, 2019, 07:27
Anak's Avatar
Anak Anak is offline
Stranger
Re: CPS easy access
If you cut a hole and just leave it you are going to have issues with dust and water vapor coming into the cabin. Might not matter for a trail rig, but I sure wouldn't want that for a daily driver.
If you want to cut a hole and seal it then you need another piece of that firewall from another XJ. That piece needs to be cut at least an inch bigger so that you will have at least a 1/2 inch flange with which to attach and seal the cover plate.
I made an access hole for the fuel pump in my Suburban. I got a donor piece of floor pan from a junkyard. I used strips of 1/8" x 1" flat bar for my nut strips on the back side (I just drilled and tapped the flat bar). I sealed it with butyl tape. Corners of the access hole were made with a drill bit so as to eliminate stress risers and all edges were deburred and sanded smooth before being painted so as to attempt to hold the tin worm at bay. Doing the job right is more than just cutting a hole.
Baby it's cold outside.
Old September 18th, 2019, 14:33
old_man's Avatar
old_man old_man is offline
Re: CPS easy access
lower the back of the tcase and use a LONG extension and the cps is very easy.
Tom Houston - Former Colorado Chapter Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old September 18th, 2019, 15:00
Re: CPS easy access
I did say fab(ricate) a plate.....
4 insert nuts etc
Old September 22nd, 2019, 16:53
Re: CPS easy access
So do you guys use tape or wire on the end of a 2ft extension bar to keep your multi meter on to test it?
Haha
Old October 12th, 2019, 16:01
waxer's Avatar
waxer waxer is offline
Re: CPS easy access
Haha
The connector for it is easily accessed from the engine compartment. You can easily back probe the connector to get a wave form on a scope... that's how I determined mine was bad.
Replaced it after a nice selection of long extensions and haven't had any problems since.
Old October 12th, 2019, 18:36
Einulfr Einulfr is offline
Re: CPS easy access
Doesn't get much easier than reaching straight down from the engine bay, unless you have canned hams for hands.
where is an easy place near front seats to access power line for fuel pump? jmg222 Modified Tech Discussion 10 October 13th, 2015 23:39
Easy question, not just easy, but SUPER easy!! LYKOS OEM Tech Discussion 3 August 12th, 2011 17:34
Nicolet NF access plan We are loosing 2500 miles of access! WB9YZU Midwest Chapter 7 July 24th, 2008 18:05
Easy Access Camp Sites near Fresno? selarep Sierra Chapter 11 October 25th, 2007 19:11
WHAT LONG ARM KIT? THE BESAT WITH EASY ACCESS TO T CASE? JEEPTUBE OEM Tech Discussion 3 June 1st, 2006 19:41
